跳转到主内容
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
20 个问题 查看全部
Where can I buy battery for Dell XPS 13 9360?
I have tried searching for it on Dell website, not much luck there. I am looking at eBay now, would you recommend to buy one there?
  • It’s Dell XPS 13 9360 which I bought more than 2 years ago. Great laptop, still feels like new, only thing - battery lasts for 3-4 hours instead of 8-9.
Dell XPS 13 9343/9350 Laptop Battery
Thanks!
Replace a 6930 mAh battery compatible with Dell XPS13 9343 9350 model laptops. 52 Watt Hours (Wh). 7.4 Volts (V). Part #5K9CP, 90V7W, DIN02, JD25G, JHXPY.图片
产品
$69.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You can but just buy a newer one
这个答案有帮助吗?
得分 0
4条评论:
Do you mean newer battery? I am little confused, is this one used? How could you tell? Could you share any other link where I can find good battery? Thanks!
完成的
No that one is fine I’d buy one that has 4 to 5 star rating
完成的
@apple_fixnoah ok, sorry for repeating myself but this one has 4.7 rating so you would buy it right?
Also, this one, for example, is more than 2 times expensive, what can be the reason? Is this one knock-off (maybe good but still knock-off) or what?
https://www.ebay.com/itm/NEW-OEM-GENUINE...
完成的
It could be a better quality one I would buy it
完成的
添加一条评论
添加你的答案
Konstantine Shengelia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 230
