跳转到主内容
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
Dodge CARAVAN 2003 Why does my van stall?
Hi..thought it was the fuel filter so replaced that but van still stalls after driving for a couple of miles. Bought fuel injector spray…no luck. Neighbor says it is not the fuel pump. Car starts again after it cools. Kristina
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Clean your throttlebody, sounds like as long as the engine is cold, the computer controls a little extra air into the engine and it runs good, as soon as the engine warms up, the idle controller no longer is bypassing air and the engine stalls. Will it run better with the AC on? If you keep your foot a little on the gas pedal, can you keep it running a little bit off from idle?
这个答案有帮助吗?
得分 1
1条评论:
Yes Duane.that is exactly what happens THANKS
完成的
添加一条评论
If the cleaning doesn’t do the trick, maybe replace the pcv valve, about 5 bucks at the auto parts store.
这个答案有帮助吗?
得分 1
添加一条评论
Thanks Joe! If throttlebody cleaning doesn't help will replace pcv
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kristina Daniels 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 172
