跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
710 个问题 查看全部
Random White / Grey Screen and occasionally Black
Apple iMac "Core i5" 3.1 27-Inch (Mid-2011) - Running macOS High Sierra version 10.13.6.
Mac boots up fine and everything is working as normal, can be surfing the net or doing some work but then a good few weeks ago the screen started to randomly go a White / Grey colour (Does not happen all the time, and nothing in particular seems to trigger it), then a few days ago the screen started turning Black at random times and would reboot itself.
Have replaced the ram to see if that may have been causing the problem but unfortunately it is still happening. not really sure what else to try.
Any help would be appreciated
Thank You
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
My first guess would be failing GPU. A very rampant problem on all MacBook Pro 15” and iMac 2011’s.
这个答案有帮助吗?
得分 1
1条评论:
Is there anyway I could check / test to see if it is definitely the GPU.
完成的
添加一条评论
添加你的答案
Kian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 77
