跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
sim reader with a broken trace
Hi, i bought an iphone to have a play with and inside was butchered, managed to get most sorted however the sim reader was removed and looks like a trace went with it.
It has five of the six contacts on the logic board but one is black.
any way of fixing this?
Many thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Do you see any copper at all? There is usually a small pin hole that is in the middle of all that black. Post a pic, I may be able to save it if I see the damage.
这个答案有帮助吗?
得分 2
5条评论:
Can't see any hole. What way does the trace go? does it always go downwards through a hole or does it continue under the aluminium cover? Cant see any copper at all
完成的
Yea that is difficult to see. The trace goes to the back of the board I believe. I am afraid that you may have an ipod touch at the moment.
完成的
Just so you know and anyone with this problem, I have successfully fixed it. I done my research to find that pin 5 can be NC or VPP which is an optional pin. I soldered a new sim reader and all is fine..
Full signal and contacts etc, the only thing I assume you lose is the abilty to write to sim (if thats even used on an iphone)
Any way thanks for your help hectordtruong and so remember this if it happens to you :-)
完成的
That's awesome Luke, this post will be very valuable for anyone in the future with the same problem. Thanks for posting the results!
完成的
添加一条评论
添加你的答案
Luke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 626
