跳转到主内容
Water dispenser works. Ice-maker doesn't.
I have a Whirlpool Refrigerator Model WRS571CIHZ00. The water dispenser has a strong flow, but it just decided to stop making ice completely. I have disassembled the ice-maker/dispenser and checked the wires, didn’t see anything. I decided to check the continuity on the inlet valves and for some reason they all read zero. I double checked and it all reads zero. this is frustrating because I had the fridge less than 2 years. What makes it more frustrating as that I have flow to the water dispenser. Not sure what more to check. My next thought is that it could be the mother board. Someone have any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Water Inlet Valve
The water inlet valve is an electrically-controlled valve that opens to supply water to the dispenser and ice maker. If the water inlet valve is defective, or if it has insufficient pressure, it won’t allow water to flow through. As a result, the ice maker won’t make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi. If the water pressure is sufficient, use a multimeter to check for power to the water inlet valve. If the water inlet valve has sufficient pressure and is getting power, but the ice maker won’t fill with water to make ice, replace the water inlet valve.
here’s a video on how to test it correctly:
https://www.repairclinic.com/RepairHelp/...
这个答案有帮助吗?
得分 3
1条评论:
Replaced water inlet valve and pressure is good, no water to icemaker
完成的
添加一条评论
had the same exact problem when my freezer ice machine stopped making ice. under warranty, the technician found that the water has frozen at the inlet of the ice machine. check the two water tube at the back of your fridge and follow the one that goes to the ice machine. you may use an hair dryer to melt the ice in the tube. i dont know how, but the tech manage to isolate the tube to prevent it to freeze again. no problems since 4 or 5 years now...
这个答案有帮助吗?
得分 0
1条评论:
Exactly what I found when the water dispenser was functional and the ice maker was not. The inlet to my ice maker is at the top of my fridge so pulled it up and found a chuck of ice. Pulled it out and water flowed immediately so a great sign. Unfortunately I had replaced the water inlet valve when it was not needed. Anyway I have ice now.
完成的
添加一条评论
添加你的答案
echols.kris 将永远感激不已
浏览统计数据:
过去 24 小时: 20
过去 7 天: 145
过去 30 天: 637
总计 16,548
