跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Cameras, light, earpiece speaker not working after battery replacement
After I put in a new battery (without removing the screen) both camras, the light for the rear-facing camera/flashlight, and the earpiece speaker are completely dead. Everything else seems to be working fine, and I can’t see any damage anywhere. I checked the connections to see if something might have pulled out because I didn’t remove the screen all the way, but I can’t see anything wrong and they’re still not working. Suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It sounds like the display and camera connectors were torn.
If you connect a known-good display or camera module to your iPhone, what happens then?
这个答案有帮助吗?
得分 0
添加一条评论
If you see a cable like this Picture, you have to replace it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Spitzer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 50
