跳转到主内容
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
Can I upgrade myself SSD on 2019 MBP 15?
Just bought a 2019 15” MBP with 256 GB SSD. (On sale in Costco, not configurable).
Can I replace it with my older 500 GB SSD from my previous MBP?
If the answer is yes, anyone knows it it would it void Apple’s warranty?
Thanks in advance for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sorry, no you can’t swap out your SSD’s. While your 2015 or older Retina model has a removable SSD, the newer 2016 onward Touch Bar systems have soldered storage which can’t be altered.
But! you can remove your old systems SSD and place it within a case to use it as an external drive. That might be useful if your older system has died and not repairable OWC Envoy Pro - Portable, Bus-Powered USB 3.0 Storage Enclosurefor select Apple Flash SSDs from most 2013 to 2015 Mac Models
If you are trying to copy off your stuff to your new system there are other ways to do that YouTube - Using Apple Migration Assistant
这个答案有帮助吗?
得分 6
1条评论:
Thank you Dan for your answer.
Appreciate it very much!
完成的
添加一条评论
添加你的答案
Saul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 27,891
