跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
Too slow when booting and using applications
My MacBook Air 2017 suddenly started to lag . Tried the PRAM and SMC reset. Works the same way in safe boot and the problem is still occurring after doing factory reset over 3 times.
Here is the Etre Report:
EtreCheck Report
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You appear to have upgraded to macOS Catalina 10.15. Did you make sure you’ve applied all of the updates? Apple did have some issues with the first release. You do appear to still have a lot of 32 bit apps which you’ll need to remove.
At this point I would run Disk Utility to check the drive. Frankly, I don’t find Etre that useful when looking for performance issue related to hardware and/or OS.
这个答案有帮助吗?
得分 2
6条评论:
Dan, this problem has been occurring prior to macOS Catalina update.
I have a previous question. if you can help me out.
you recommended me a TG pro
Takes over 2 minutes to boot up, lagging while opening apps .
完成的
I think your best solution is to wipe the drive completely and re-install macOS. You do appear to have a few extra partitions which you shouldn't need.
I wonder if you are facing a rogue application or process which you haven't isolated out. It could even be malware or spyware. You do have a few processes which I have no idea what they are doing here.
But yet again, I haven't played with Catalina yet as I can't alter my systems as I still use 32bit apps. Sometime next year I likely will make the leap (may even get a new system). Until then I have no answer for you.
完成的
Dan.. Thank you for helping me out.
This problem has been occurring before I updated to Catalina. I have wiped the drive clean more than 10 times.
This is a new question for my previous problem I addressed in Takes over 2 minutes to boot up, lagging while opening apps ..
You even tried to help me by telling me to dry out my laptop.
完成的
Yes, I checked out what I had stated before. It's still possible humidity played a role here.
As for Catalina Vs Mojave, the main point is I just don't know all of the processes it has Vs Mojave and as I stated you appear to have extra partitions! Which need to be deleted, re-installing won't fix that and you may have indeed formatted the partition but that didn't remove the extra partitions. The only way I know of to do this is to boot up under an external drive and running Disk Utility from it Nuking everything and then rebuilding the drive.
完成的
Thank you for your time and you help.
I am not a techie by any means , but can you explain me thi parts from etre report that what are other processes?
Top Processes Snapshot by CPU:Process (count) CPU(Source-Location) Other processes 81.33 % (?)EtreCheck 16.98 % (App Store)accountsd 1.00 % (Apple)trustd 0.47 % (Apple) ContactsAccountsService 0.46 % (Apple)
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Ojaswi Jaiswal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 213
