跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Keyboard And Trackpad not Working
My keyboard is not responding at all, the caps lock light doesent turn on and all my function keys aren't working. My trackpad also does not function but i can still click and force click although nothing responds. I have a keybored and mouse connected that do function correctly although when disconnected the computer starts to search for any Bluetooth keyboard or trackpad/mouse. It shows up with a no drivers icon in the near top right of taskbar. I have tried to restart my computer and SMC reset, it didn't work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did you have a liquid spill into your keyboard or touchpad?
Or, did you sit your system down on a wet surface?
完成的
@danj No. I haven't spilt anything on it nor did I place it on a wet surface. When it stoped working I was on playing a game and then none of my controlles worked.
完成的
添加一条评论
1个答案
最有帮助的答案
Then that’s pointing to a battery issue, What is likely happening is the battery is swelling up pressing on the cables. Haven’t seen this happen yet in the newer 2016 onward systems. Excessive online game play can overtax the power system.
Lets check the battery, you’ll want to use a Bluetooth keyboard and mouse to gain enough control to do this. Once you have access download this gem of an app CoconutBattery take a snapshot of the main window and post it here for us to see 在已经存在的问题里加入图片 that should give us an idea where things stand.
For now I would hold off pulling the bottom cover as soon as you do the pressure of the cover will allow the battery to expand quickly and it could rupture! If you can lets run the battery down as the less power stored then less fire risk.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
thingy person 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 260
