跳转到主内容
加入维修社区 - 创建账户
A1418 / EMC 3068 / iMac 18,1 / 2.3 GHz dual-core i5 processor. Released June 2017.
2017 display assembly compatibility.
Is the 2015 lcd assembly compatible with 2k 2017 Imac 21.5 ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There are two versions of the 2015 21.5” iMacs the Non-Retina and the Retina 4K display version:
iMac 21.5" LCD Display Panel - Non-Retina - Apple P/N 661-02989 - LG Display: LM215WF3 (SD)(D5)
iMac 21.5" LCD Display Panel - Retina 4K - Apple P/N 661-02990 - LG Display: LM215UH1 (SD)(A1)
Now let’s look at the 2017 versions which likewise have two versions!:
iMac 21.5" LCD Display Panel - Non-Retina - Apple P/N 661-07321
iMac 21.5" LCD Display Panel - Retina 4K - Apple P/N 661-07322 - LG Display: LM215UH (SD)(B1)
From all indications the displays are not compatible either way.
这个答案有帮助吗?
得分 0
2条评论:
I just installed a 2015 Non-Retina display on a 2017 Non-Retina imac and it works perfectly!
完成的
@pjvcc - The newer version display is a bit brighter.
完成的
添加一条评论
添加你的答案
Henri Nicaise 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 816
