跳转到主内容
The PowerBook G4 Titanium Series was initially announced at Steve Jobs' keynote at MacWorld Expo in January 2001.
logic boards interchangable?
I have the above machine with a defective logic board. I bought one on e bay and now am ready to install. The problem: the resident defective board is 400 Mhz and the one I bought is 500 Mhz. Will it work if I install it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes you should be able to swap the logic boards between the 400/500/550/667MHz VGA models. But you cannot use the VGA series with the 667/800/867/1GHz DVI units.
这个答案有帮助吗?
得分 3
1条评论:
I am replacing a PB G4 Titanium DVI 667mHz logic board with a 867mHz logic board. I also have been told that all of these DVI models except the 667 had a secondary fan, so I have ordered one of those fans, but don't have it yet. But the 887 that I have installed has no socket to plug the fan into, as far as I can see. The primary fan is plugged into a socket next to the fan itself, as was the 667 primary fan. My question is: Where does the secondary fan plug in? Please help me find the answer. Thanks, RHBernard@gmail.com
完成的
添加一条评论
For the previous answerer:
lemerise
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
russ heagle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,243
