跳转到主内容
Guides and repair information for coffee and espresso makers from Jura Elektroapparate AG, a Swiss developer and distributor of home appliances.
99 个问题 查看全部
Model Jura A1 the brew group motor rotates continuously.
The brew group motor rotates continuously in the same direction.
I change the encoder, but the problem persists.
What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
最有帮助的答案
Did you have the brew group apart?
I had this issue when I took the brew group apart and didn’t get the lower plunger in all the way when I assembled.
这个答案有帮助吗?
得分 1
添加一条评论
I’m working on a Jura A1 when starting it cycles a few times and shots off what’s the problem ?
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem. I dissaembled the brew group, I disconnected all the the connectors on the motherboard, then i disassembled the brew motor. I checked the encoder who is connected to the brew motor, it’s sensible so verify the encoder is well assembled to the motor with the metal “spring”/connector. assemble the motor (assembled with encoder) then the brew group and try again.
这个答案有帮助吗?
得分 1
1条评论:
What is the "Encoder" ? where it's located ? on the motherboard ? I have some electronics skills
完成的
添加一条评论
I have this issue, motor rotate non stop after I unmounted this part and cleaned it. Will try your tips, thanks !
这个答案有帮助吗?
得分 0
添加一条评论
It’s the brew group had the same problem took apart the brew group lowered the inside, plunger one notch, and it worked
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
peri co 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 403
