跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Black screen on MacBook
Hello, so today I went to turn on my MacBook, but I was met with a black screen . Yes it is charged, yes I checked to see if the brightness was down, and yes, I tried all of the VRAM reset solution things that are suggested. None of them worked. The MacBook itself seems to turn on, as in all of the keys are lit up, and the caps lock lights works, but it seems that the problem is with the display. I have also noticed that when I shake my MacBook, I can hear and feel something moving around. Is this the issue? Did a cable get unplugged or broken?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
most probably your unit was subjected to fall, thus you hear there is something loose inside. the bad news are that all the connectors are fixed with the retainers by screws, so what you hear most probably are some of the screw's mounts are broke off. take a look inside. avoid further shaking since you never know where those loose parts will end up in there. avoid powering the unit on if you can. post the pics with what you'll find.
完成的
添加一条评论
1个答案
最有帮助的答案
@ckelly27 … could be a backlight issue. try to shine a flashlight at the screen or behind the back on the apple logo to see if you can see an image. if so, the backlight circuit needs to be repaired. if not, further diagnostics are required.
post back with findings for any additional assistance.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cameron kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 14
总计 225
