跳转到主内容
7.9 inch android tablet manufactured by Acer in 2013.
32 个问题 查看全部
Why my Acer Tablet isn't charging
Good Evening: My name is Toni Jordan. I would like to know why my Acer Iconia A1- 810 tablets are showing a green icon and not showing the battery to charge. My tablet is’’t charging, and I would like to know it is’’t charging!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi Toni,
if it looks like it’s charging, it would be battery issue - your battery is out of date and needs a replacement.
But for sure, first, check if your cable is OK and also if the power adapter is working properly, try different type of cable and adapter, then check, if the connector in the tablet is fine and is not damaged, clean it from the dust and try to charge. If it’s still not working, try to recover your tablet to the factory settings. If it’s still same, it’s time to replace your battery.
这个答案有帮助吗?
得分 1
添加一条评论
There could be several reasons why your Acer tablet isn't charging:
  • Damaged charging port
  • Faulty charging cable
  • Dead battery
  • Defective charging adapter
  • Software issue
Try using a different charging cable and adapter to see if that resolves the issue. If not, try resetting the tablet or taking it to a repair shop for further assistance.
这个答案有帮助吗?
得分 0
2条评论:
@sami78, your link doesn't work. Please use good judgement when posting links to a company you're associated with, as iFixit seems to have a very strict policy on spam.
Your post, while relevant and informative, could easily be viewed more as an attempt to promote your website rather than a sincere effort to help, especially when you're posting on a four year old thread with a link that doesn't work.
完成的
sir check again that link, it's working
完成的
添加一条评论
First, power down your device, unplug the USB cable and wait 10 seconds. Next, plug the USB cable back in and power the device back on. If cable still does not work, ensure you are using the most recent USB driver.
Regards,
Will
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Toni Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 41
总计 835
