跳转到主内容
加入维修社区 - 创建账户
Welcome to the Fast Fix project page! The Fast Fix project is part of iFixit's University Technical Writing program. This project is all about quick and simple fixes for household items like bikes, guitars, toys, and more. If you are a student looking for more information on the Fast fix project, please visit edu.ifixit.com and click on the "Fast Fix" project type.
Can anyone tell me how do I use the flex extension?
Can anyone tell me how do I use the flex extension in Ifixit pro tech kit?? It’s not magnetic.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
1条评论
The Flex Extension in the iFixit Pro Tech Toolkit is a bit confusing at first, but it’s simple once you know it.
### How to use it:
* Insert the extension into the driver handle first
* Then attach your bit (screw head) to the front end
* Use it like a flexible shaft for tight spaces
### Important point:
* It is **not magnetic on purpose**
* It holds bits with a **friction fit**, not magnetism
### Tip:
* Push the bit in firmly until it feels locked
* If it feels loose, re-seat it again
It’s designed for reach, not magnet strength.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi @kmredul
Push the bit into the hollow end until it is stuck in place. It will need to be pushed a little harder versus putting the bit directly into the driver. If the bit is not magnetic, you can attach a small magnet to the bit or rub the bit itself against a larger magnet.
这个答案有帮助吗?
得分 13
2条评论:
Yeah, I figured it out. BTW thanks for your help.
@refurbpro
完成的
Man I feel dumb. Thank you.
完成的
添加一条评论
The 150mm Flex Extension in the 64 Bit Driver Kit (Mako/Pro Tech Toolkit) does not have a magnet. The slot uses friction to secure the bit, unlike the iFixit Drive Handle which uses a magnet. If you insert a bit and then push it in with additional force it will click into place. To remove the bit, simply pull the bit up and out from the socket and the friction grip inside will release it.
If you're not able to get the extension to hold the bit, please Contact Us with your order number.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Khaliduzzaman Mredul 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 43
过去 30 天: 178
总计 5,907
