跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
375 个问题 查看全部
iPhone XS Max restarts every 4 minutes after screen replacement
I have an iPhone XS Max that appeared fine after a screen replacement. The screen is aftermarket, and the phone now restarts every 4 minutes. Everything seems to work fine in those 4 minutes, battery charged, cameras work, touch works, receives texts, makes calls. Is it just a bad screen? Already tried updating all of the apps and even restored the phone. I have the phone coming back in and will put the original back on to see if that fixes it. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
7条评论
update: phone came back in and original screen did not fix the problem. Have tried to restore again, and use TenorShare to fix any issues software wise. Still no luck.
完成的
Any update on this issue?
完成的
Still no updates or answers from anyone
完成的
Welcome to the modern times of aftermarket screen replacements.
完成的
Hey Matt,
I used to work for Apple and am assuming you did the screen replacement at a place that wasn't through Apple. You mentioned you already got the original screen back on which didn't help to fix the restarting issue. Is that phone still under the original 1 year warranty through apple? I assume that you didn't get Apple care otherwise you would have done the screen replacement through them?
完成的
显示更多的2条评论
添加一条评论
2个答案
最有帮助的答案
The charging flex cable might have been damaged during screen replacement. Or you can also check the USB IC as mentioned in the repair guide here.
A rare case of iPhone X Keeps Restarting - Motherboard Repair
这个答案有帮助吗?
得分 2
添加一条评论
change the frames 100% worked!
这个答案有帮助吗?
得分 0
1条评论:
What do you mean change the frames
完成的
添加一条评论
添加你的答案
matt mocciola 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 27
总计 4,100
