跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
101 个问题 查看全部
iPad is disabled connect to itunes on MacOS Catalina
Hi, I have a ipad with error message “iPad is disabled connect to itunes” but itunes is no more available on MacOS Catalina !
Can somebody please help me to restore this ipad ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
No one has yet found an answer. Apple sure stuffed getting ipad back alive
完成的
添加一条评论
7个答案
最有帮助的答案
Check this out, it is still possible to restore an iDevice on Mac OS Catalina:
https://www.imore.com/how-sync-your-ipho...
这个答案有帮助吗?
得分 3
添加一条评论
Hi, Thank you for your answers ;-)
I finally found the solution. iPad was managed by “apple configurator 2”, so I started the iPad in recovery mode and connect to “configurator 2”. Then click on “recovery”.
Best regards
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much! This did the trick. I downloaded the configurator and clicked around with update (I believe I had to restart the iPad once to get the process going). It installed a new operating system.
完成的
添加一条评论
hey! did u find out?? im having the same problem rn and i don’t know what to do lol
这个答案有帮助吗?
得分 0
添加一条评论
This is the official article on how to fix what you’re experiencing:
https://support.apple.com/en-us/HT204306
这个答案有帮助吗?
得分 0
1条评论:
it didn't work :(
完成的
添加一条评论
You know what? I read an article about this exact same problem!
So here is it: iPad is disabled connect to iPad
Basically, you hook up your iPad with your mac, and you will see a notification telling you to restore the iPad.
If not, the easiest solution is to use Joyoshare iPad System Recovery to restore the iPad without data loss.
这个答案有帮助吗?
得分 0
添加一条评论
Resetting the ipad can be done using the Finder on Mac OS Catalina.
  1. turn off iPad and unplug from Mac
  2. start Finder
  3. press Home button
  4. plug iPad in while Home button is pressed
  5. iTunes logo will appear on the iPad
  6. iPad will appear in Finder
  7. a prompt to update or reset to factory settings will appear on the Finder.
  8. Follow on screen instructions to update or reset the iPad
This video demonstrates this process.
这个答案有帮助吗?
得分 0
添加一条评论
if you have a separate device like windows you can use iTunes from there, or upgrade to a newer version of mac os
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Guy Lerou 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 8,296
