跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 个问题 查看全部
Unit turns on then abruptly shuts off during mid-chime
My troubleshooting with this issue thus far….
  1. With everything connected, when turned the unit on, it starts to chime and then abruptly shuts off.
  2. If I remove the display, the unit turns on and chimes and stays on. Given that, I decided to try a different display but had the same issue.
  3. In terms of the display, If I remove the LVDS cable only and leave the black cable plugged in, the unit turns on and chimes and stays on.
  4. In terms of the display, If I remove the black cable and leave LVDS plugged in, the unit returns to the same issue, i.e. shuts-down during chime.
  5. The Power LED lights on the motherboard all act normally with the display removed.
So not sure what is going on. Given the test plugging in the LVDS cable, it sounds like it might be an issue with the video controller on the motherboard but looking for advice in terms of anything dealing with this kind of issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Not sure what you’ve tested here as it’s conflicting. Looking at the logic board with the display disconnected you should see the first three onboard diagnostic LED’s
If you plug the display cables in and after restarting the system all four LED’s should light.
Tell us what you see
这个答案有帮助吗?
得分 1
4条评论:
Thanks for the help.
Based on what you asked me, here are the results.
1. With the display disconnected, when I plug-in the power cable, LED#1 turns on solid. When I press the power button, the unit chimes and then LED#2 and LED#3 turn on solid. LED#4 stays off.
2. With the display connected, when I plug-in the power cable, LED#1 turns on solid. When I press the power button, the unit starts to chime and then abruptly shuts off. At this point. none of the LED lights are on.
完成的
The LED's are telling us your logic board GPU logic is OK, But it does appear your display its self has a problem!
Did you insert the cable correctly? You may have damaged the data cable or socket and/or the power socket and the its cable.
Can you give us a bit more info on what happened. Post some pictured of the connectors and cable ends so we can see 在已经存在的问题里加入图片
You may need a new display assembly.
完成的
Sorry but I mentioned in the original post that I thought it was the display assembly but I tried a new one and still had the same issue. Unfortunately, the replacement panel did not come with a new LVDS cable so I had to move it from the old one. Is it possible that cable is bad?
Basically, machine was in service working when this issue started. So this was not as a result of doing any prior work on it.
完成的
Wondering if its possible that the Power Supply is shorting out when the display is attached? Anyone seen this kind of behavior?
完成的
添加一条评论
添加你的答案
jstephen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 18
