跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
iPhone XR sensitive dongle causing random playback issues
I’ve tried listening to several different apps and always have the same problem and I’ve also tried different earbuds (with cords).  The dongle seems sensitive and every time it is touched a certain way, it causes apps to have a mind of its own and even skips whole episodes of podcasts, pauses, and plays.  I can’t workout with music because if I just walk, it stops the music and it is infuriating.  How can I fix this without having to buy Bluetooth earbuds?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you are referring to the lightning to 3.5mm headphone jack adapter then the socket on the adapter is worn out which means you'll need to buy another lightning to 3.5mm adapter.
Try cleaning the socket with something like 95% isopropyl alcohol and a cotton swab (remove some of the cotton to get it to fit in).
这个答案有帮助吗?
得分 1
1条评论:
yup. i'm pretty much gonna have to replace it. That's what i get for not having a protective case for so long.
完成的
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 2,829
