跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
LED501 (#1) is on but nothing when the button is pressed
Hi,
I’ve got a A1312 and try to fix the problem :
The first led (LED501) is on, means that the power supply is good ?
But when I press the button to power up the iMac, nothing is happening, LED502, 503, 504 stay off.
I think the problem could be the button or the power supply ?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Have you tried jumping the button contacts at the logic board?
It does sound like you have a bad power supply iMac Intel 27" EMC 2309, 2374, 2390 or 2429 Power Supply and here’s the guide iMac Intel 27" EMC 2429 Power Supply Replacement
Often a power surge or a lighting strike will kill your power supply. Do make sure you have a good surge suppressor (not a power strip which has no protection), better yet get a good UPS!
Replace a broken or damaged power supply compatible with an iMac 27" Intel (Late 2009 to Mid 2011).图片
产品
$149.99
这个答案有帮助吗?
得分 2
2条评论:
Hi,
Yes I have tried to jump the button contacts on the motherboard but still nothing.
Could the motherboard be dead ? Or it’s only the power supply?
Thanks!
完成的
Time for a new power supply
完成的
添加一条评论
添加你的答案
Alexis Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 170
