跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
Replacement Battery Dropping Suddenly to 7%
I’ve just replaced my battery using the kit from iFixit. Everything seemed to go well according to coconutBattery , and I calibrated it per the instructions (full charge -> use it until it goes to sleep and wait -> full charge).
For some reason, when I start using it, the battery discharges normally for some time, then drops suddenly to 7%. It will stay usable on 7% for quite a while, then it dies.
30 minutes later:
This happened on the first cycle, and after I charged it fully (which was slow, took ~ 5hrs - not sure if that is part of the same problem), it has happened again.
It seems other folks have had similar problems with these replacement batteries - is there any way to fix this? Are there any reliable sources for these batteries? It is quite an involved process to try new batteries until finding one that works if so many being shipped are unreliable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Sorry for the bad luck, contact the store to get a free replacement!
这个答案有帮助吗?
得分 3
2条评论:
Shoot, I was afraid this was going to be the answer. Thanks for the info.
Do you happen to know if the adhesive on the replacement batteries is easier to remove, or will I need to go through the same process again?
完成的
The adhesive should be a bit easier to break the bond to the case using the same method as before.
完成的
添加一条评论
添加你的答案
mp_fix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 175
