跳转到主内容
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
Battery keeps going bad in same device
Here’s the scenario: My customer is a pilot who flies small, private planes. He uses the iPad Air 2 to file flight plans and as a navigational aid. The device is always with him when he flies. It has had some bumps and bruises, the frame was bent at one point, but we were able to straighten it out. Overall, it functions just fine.
May 2018: I replaced a very swollen battery in the device. (The glass was separating from the frame.)
January 2019: The May battery was swollen and again, the glass was separating from the frame. I replaced that battery, straightened the frame, and sent him on his way.
October 2019: Battery is swollen again.
Any ideas as to what could be causing this device to go through batteries so frequently?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Does he leave it plugged in the entire time he’s using it? If so I would imagine it would be from that. Also, depending on the altitudes he’s flying at, the lack of air pressure could cause the battery to swell as well.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeana Morales 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 122
