跳转到主内容
加入维修社区 - 创建账户
Repair information for the first generation Apple iPad available in Wi-Fi and 3G versions with 16, 32, or 64 GB of storage. Released on April 3rd, 2010. Model numbers: A1219 and A1337.
iPad won't enter DRU nor Recovery Mode
I have tried multiple ways and directions on how to get this iPad, it’s model a1458, into either recovery or DFU mode, neither are working.
  1. When I try holding both power off and home button and never release them, it just keeps turning off, then apple logo, then off, then apple logo (keeps looping).
  2. When I try holding power and home to turn off, then when black screen release power but keep holding home, it just goes back to the ipad disabled screen.
  3. When I try holding home and plugging into USB it boots up to ipad disabled screen and itunes never finds it.
  4. I’ve tried all of the above with USB connected, then again without USB.
  5. I’ve also tried #2 with USB first unplugged, then when black screen plug into USB.
So I’ve tried a lot of combinations, I’ve also done this to other ipads before without issue, this one is belligerent.
Any ideas to get into recovery or DFU? I’m trying to factory reset without original icloud account since we don’t have it. Attached is what is on the screen now, it won’t connect to itunes anymore either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
3条评论
i have the same problem, any help or advice would be great
完成的
So no answers to this at all? I am in a similar boat…..
My daughter's iPad is disabled because she messed about with the passcode. I have tried connecting to itunes/Finder however when attached to my Macbook, nothing happens. It is as if the computer does not detect the iPad. Because of that, I am not able to go into Recovery Mode. The iPad just keeps looping on and off and finally back to the "iPad disabled connect to itunes" screen. I have tried this with two Macbooks and several different charging cables so I know these are not the issue. I thought it was a hardware problem (the lightning port) but the iPad could charge using the wall outlet, but not when connected to any of my computers.
I have brought the iPad to some local mobile repair shop to try to go into Recovery mode but even they could not do it (iPad not detected by their computer too) and suggested that the issue might be with the logic board/ lightning port. I just wanted to check if anyone has found a solution to this before I proceed to just have the board replaced.
完成的
I know this article is a couple years old, but here is what I had to do. When my Ipad min refused to go into DFU mode on my mac I simply installed itunes on a Window10 Laptop. Held power and home button until Itunes said Ipad was in DFU mode and had to be rest to use with itunes. Funny why this worked but trying on pure Apple based platform no luck.
完成的
添加一条评论
2个答案
最有帮助的答案
USB - C which is pretty much standard just won’t work… USB A on the Mac is what’s need,
这个答案有帮助吗?
得分 6
4条评论:
wow... that freaking worked. I even had new USB C to Lightning cables...
完成的
OH MY FREAKING GOD!!!! I have been trying for sooo long!! Thank you. This worked straight away so thank you so much!
完成的
What the F.... it's true. I tried for an hour then read this. Then used a Lightning to USB-A (with an Adaptor USB-A to USB-C) and it worked
完成的
Just want to add here because I was looking for a solution - It actually work! Thanks!
完成的
添加一条评论
Hi @jfreak53
Tried and true way to get older apple products into DFU/Recovery mode is to plug the device into a computer, hold the power button and select shut down the device, then immediately hold the home button (while it shuts down and starts back up) for ~15 seconds until it boots up into recovery mode.
In my experience, this will not remove the iCloud account signed into the device but older versions of iOS might be different.
这个答案有帮助吗?
得分 1
12条评论:
Still didn't work, went back to the same screen.
完成的
Can you verify that the charging port isn't damaged and that the home button is working properly? Both these parts need to be working 100% for the iPad to enter DFU mode
完成的
When I press home button, screen turns on. When I plug into charging port it starts charging from PC or charger, so I would say, yes.
完成的
Tried about 30 times, then it worked. Could get the grey screen but not the screen with the text support.apple.com/iPad/restore. Finally it worked.
Suspect semi bad cable or not perfectly working home button is the issue.
完成的
For me, trying with a different cable worked
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Joel DeVenney 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 78
过去 30 天: 275
总计 16,918
