跳转到主内容
加入维修社区 - 创建账户
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
MacBook Pro won't power on after I remove the battery
I just removed the battery from my MacBook Pro, and it will not turn on when plugged in. The battery removal was necessary; it was very swollen. I have the original charger, and I have plugged the MacBook in as if I was charging it. However, it will not show any signs of turning on, besides the green LED on the charger. Does anyone have any recommendations as to how I can fix this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
So you took the battery out and then put the same battery back in, is that correct?
完成的
添加一条评论
2个答案
最有帮助的答案
Time for a new battery!MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery and here’s the guide 2010年中期MacBook Pro 15寸 Unibody 电池更换
Your system won’t start up without a battery installed which is working.
Replace a 7080 mAh battery compatible with MacBook Pro 15" Unibody (Mid 2009/Mid 2010). 77.5 Watt Hours (Wh), 10.95 Volts (V).图片
产品
$79.99
这个答案有帮助吗?
得分 1
添加一条评论
Not all macbooks need to have a battery in to turn on when it is plugged in it should work! It can depend on the max wat of your charger in that factor of what you had tried to do!
Laptop is having other power issues remove some ram reseat test ram
It could be some other bad hardware
Bottom plate should be on not screwed down
这个答案有帮助吗?
得分 0
2条评论:
The Airs & Retinas will work without a battery the Unibodies need the battery.
完成的
Do you have a fresh battery?
完成的
添加一条评论
添加你的答案
Gavin R. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 139
