跳转到主内容
Patagonia outerwear that keeps you warm on brisk days and dry on wet days. Repair difficulty ranges from simple tear patching to more complicated baffle repair.
148 个问题 查看全部
My Coat is Shedding White Dust
I recently purchased a used vintage coat and have found that a harmless white dust sheds from the interior layer of fleece. After washing and vacuuming the jacket it seemed to be fixed but after a day the dust appeared again. Any ideas on what may be happening? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Use lint roll ons on it and read the washing instruction, if any.
这个答案有帮助吗?
得分 1
2条评论:
Hi, I tried a lint roller and after a quick wear the dust appeared again. When I did my first washes I followed the listed instructions. Thank you
完成的
hi joshua, may i know if you've solved the problem or if the thing has stopped after wears. many thanks.
完成的
添加一条评论
This is likely due to the waterproof lining that is applied either on the exterior shell or internal lining. Wash will actually make it worse. If it’s internal there is no fix. If yuh hold it up to bright light you should see the dust piled up inside! Kinda gross!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joshua Konya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 1,652
