跳转到主内容
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
47 个问题 查看全部
How many OSs can I run?
I have a 1GB 1.42GHz, 80GB Combo, Airport Extreme eMac running 10.5.8.
I was wondering if I could partition my hard drive to run older versions of Mac OS. For example, like bootcamp, you would be able to hold alt at start-up and the different partitions would show.
Would it be possible to have Mac OS X, Mac OS 9, Mac OS 8 and so on on separate partitions?
If it's just a case of using firewire target mode or something that would be great.
Also, does anyone know where I could download working builds of old Mac OSs?
Thanks
UPDATE
I have those 19 files now but when I click on the first one it opens a folder with old OS files in. I cannot open them as "the classic environment is no longer supported."
How do I make an image out of them, and how do I partition my hard drive?
Thanks again
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
8个答案
最有帮助的答案
Well technically, you can run as many as you can fit. I believe if you search around you can find os 7 legally, but for the later versions, you can get them cheap off ebay.
Edit: I just realized I have 7.5.3 on my drive which I obtained legally online after much searching a while ago, if you want I can send it to you.
这个答案有帮助吗?
得分 3
7条评论:
That'd be really great, how big is it and what file type is it? I assume you mean that later versions still have to be paid for.
完成的
It's 23 mb in 19 images. This was obtained through apple's website, bought later versions can be gotten through ebay or amazon, here are a couple of links
os 8:
http://bit.ly/6Nj1OJ7
http://bit.ly/77Hna8
os 9:
http://bit.ly/5r0SpU
http://bit.ly/5aIkKM
完成的
Actually I just found the place on apples site, here it is from then:
http://download.info.apple.com/Apple_Sup...
完成的
One last comment (hopefully!), check this link from apple which contains all sorts of updates and applications you may want to take a look at (for older systems)
完成的
显示更多的2条评论
添加一条评论
Hello! Just for your info, I use an eMac 1.25 GHz with 3 partitions: 10.5.8, 10.4.11, and OS 9 Classic. I'm in education & some of my good programs require OS 9 Classic ---10.4 will still run OS 9 Classic. For example, I switch to my 10.4.11 partition using Sys. Preferences --> "Start Up Drive." Select the the 10.4 drive icon and restart your computer. When you finish using OS 9 or 10.4 in that session, just do the above directions again and return to your main drive. (Apple is so wonderfully logical this way! I'm an Apple user since the Apple IIe! I'll never go PC!) Also, try a company in Oregon called PowerMac for help with finding older program driver sources. They are just as nice as iFixit! Good Luck!
micmon224
这个答案有帮助吗?
得分 1
添加一条评论
Hi rab, thanks for all this work but the rapidshare site pretends it's busy to try and make me pay money. Can I get it some other way? E-mail maybe. Also, those Apple links say "the page cannot be found".
这个答案有帮助吗?
得分 0
2条评论:
Strange, got that for me too, but rapid share I'm sure it works if you just hit free user.
Does this work:
完成的
No, that gives the same page not found message. And rapid share still says sorry our servers are overloaded, unless of course you enter your credit card details. I'd really rather not
完成的
添加一条评论
You can also get different distributions of linux for PowerPC as well.
这个答案有帮助吗?
得分 0
1条评论:
Yes I was aware. I wasn't actually asking that though.
完成的
添加一条评论
I know that OS 9 uses Mac OS Extended formatting- perhaps OS 8 & 7 also run on that?
这个答案有帮助吗?
得分 0
添加一条评论
Morphos - http://en.wikipedia.org/wiki/MorphOS
这个答案有帮助吗?
得分 0
添加一条评论
You can't normally use an OS that pre-dates the computer. For your model that's OS X 10.4. It won't boot into OS 9 or anything earlier.
这个答案有帮助吗?
得分 0
添加一条评论
Technically, I'm afraid you can't.
No. 10.4 is the earliest that your eMac will run.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
QEII Student IT 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 16
总计 3,798
