跳转到主内容
Samsung smartphone released in January 2016. Model SM-J320
48 个问题 查看全部
Why wont my screen work?(Black Screen of Death)
Hi, so on my J3 2016, I went to turn it on one day but it didn’t. I just assumed it was dead, so I plugged it in. When I plugged it in the phone vibrated, so I thought it was charging and left it there. Fast forward 3 hours later, I come and check on it, and it doesn’t power on. How can I fix this?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
What causes you to believe this is the black screen of death? What steps have you taken to narrow this down? Your description doesn’t rule out a simple power, battery, or charging issue.
这个答案有帮助吗?
得分 0
2条评论:
I tried multiple chargers, took the battery out and plugged it in to see if it would turn on. Also, when I plug it in, it vibrates but nothing shows up.
完成的
Gotcha. You are right that it's taking a charge. I don't want to jump the gun, but out of curiosity, have you tried a hard reset using the hardware buttons?
完成的
添加一条评论
最有帮助的答案
Hi @random_user_101
Generally if the phone works properly with nothing on the screen, it is a screen related issue. You can check the screen connection easily from the connector on the backside of the phone.
If you are still having screen problems, you may need a replacement screen assembly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Random _User_101 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 23
总计 657
