跳转到主内容
The Kodak Easyshare Z981 features a 3.0 inch bright LCD screen and 26x optical zoom with a 26mm wide-angle lens. The 14 megapixel resolution makes for vivid prints up to 30x40 inches.
15 个问题 查看全部
Why will the battery cover not lock when closed
z981 battery cover will not latch
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
What do you mean?
If the battery cover isn’t staying closed, then the clip is most likely broken somewhere. If you could provide some pictures or a more detailed explanation, then further help could be given.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mrgrump 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 89
