Vertical green lines on screen after HDD replacement?
Hello there,
i recently replaced my iMac mid 2007 HDD with a SSD. Now after the replacement was done i have very thin vertical green lines on the screen.
The steps i have done so far but did not fix the problem are:
- Resetted PRAM / NVRAM
- Clean new installation of OS X
- Put off DDRAM modules
Also i took a screenshot from the desktop and the lines are visible here as well on the image. That somehow indicates to me there might be a problem with the graphic card? I just wonder because i not touched it.
These green lines are also visible immediately after the iMac is starting up after a reboot or shutdown.
There is also a white space border to the left side of the display for about 20 pixels width or so.
Do you might have any suggestions to me what i could still try to do.
There is no apple warranty anymore and i also don´t want to spend money here for getting a new graphic card (if that is really the problem).
Here´s the screenshot i took showing green vertical lines in white areas.
3条评论
The screenshot won't show LCD defects at its capturing what is held in your systems memory as you can see its just fine here. You would need to take a picture with your phone or other digital camera.
由 Dan 完成的
You are right. If looking at the screenshot on another device i also can´t see any issues.
由 Roman Müller 完成的
I noticed they are not there "permanent" again somehow. If it hit against the monitor a little they are gone but come back again at a random time.
由 Roman Müller 完成的
