跳转到主内容
The Verizon Ellipsis 8 is a tablet that features an HD display, 5000 mAh battery, and 4G LTE capabilities.
28 个问题 查看全部
Screen Showing Fully Charged Battery And Than Battery With A Question
Hey everyone, my friend was given a Verizon Ellipsis 8 that wasn't working for him, so he gave it to me to try to fix. When I plug the tablet in, whether it be in a computer or in an outlet with the adapter, I get the Android icon that shows the battery fully charged with the lightning symbol, and then it restarts and shows an empty battery with a question mark in it. After that, it goes into a loop of showing the full battery and than the question mark. Is it possible that the battery on it has to be replaced? If anyone knows anything, please feel free to respond! Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I think the problem is a dead battery. Could you try removing the battery, then plugging the charger in? Verizon Ellipsis 8 Battery Replacement
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
I am having the same problem with my Ellipsis: battery symbol, then a battery with a question mark inside. But this has happened after my tablet wasn’t turning on AT ALL. I ordered a replacement battery from Amazon, installed it myself, and NOW I am getting the battery symbol with a question mark inside. I should add that the tablet still won’t turn on at all unless it’s plugged into an outlet. But it will turn on and show the question mark symbol while plugged in.
Ive tried holding down the power button for 20 seconds, release, then hold it down for 3 seconds, but it still won’t turn on. I’ve also tried this while it is plugged in, and I can only get the question mark again.
I also read in a forum that I could try charging it through my laptop while it’s plugged into a USB for 2 hours, then plugging it into an outlet and charging it that way for 45 minutes, then it should be fully charged and should turn on, but that still doesn’t work. I can’t get past this battery/question mark issue. I would like to think that it’s a battery problem, but I just installed a brand new battery which should have been fully charged, but I’m still having issues… I’d love to not have to trash this thing or return it to a Verizon store (I don’t think they’d even take it back).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Edmond Dantes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,486
