跳转到主内容
发布于2017年8月,Galaxy Note 8是被召回的 Galaxy Note 7的接班人。Note 8于2017年9月向公众开放购买。
148 个问题 查看全部
I shattered my screen, and now a portion of it wont respond to touch.
I shattered the screen on my note 8 further, a day after ordering replacement glass for a relatively small fracture it already had. I have a little bit of experience fixing stuff like that and was planning to try to fix it on my own, however now the middle third of the screen is unresponsive to touch. Would replacing the glass fix this, or should i order a new AMOLED?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
if you can see everything on the screen perfectly fine and it’s just the glass that is shattered and unresponsive to touches replacing the glass would probably fix it but it might be much harder than replacing the whole assembly
这个答案有帮助吗?
得分 1
添加一条评论
Hi @c0nman46
As long as you ordered a quality replacement screen, all of your issues should be resolved with a screen replacement. Damaged Samsung AMOLED screens tend to degrade worse and worse over time until they do not function at all.
I’m hoping that you ordered the screen pre-installed on a frame, otherwise this will be a VERY difficult repair.
Best of luck fixing this up!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Con Coster 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 52
