跳转到主内容
Horizontal, grainy screen flicker
For at least a month now, I have noticed a randomly occurring flicker on my screen of my 2018 MacBook pro
as can be seen in the photos, the glitch appears to be in a grid of dots appearing in a vertical strip across the bottom portion of the screen
it doesn’t seem to matter what i’m doing with the laptop, there isn’t a pattern as to why its occuring
any help is appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This is likely a noise issue within the T-CON board. To double check plug in an external monitor so when you see the issue on the internal you don’t see it on the external.
The best thing you can do here is bring it in to an Apple Store or authorized service center hopefully its covered under warranty. You’ll need a new display assembly which is quite expensive! The T-CON board is directly attached to it.
这个答案有帮助吗?
得分 1
添加一条评论
I have the exact same issue. I've took it to Apple and they replaced the screen. Didn't fix the problem. Took it in again, and they said it wasn't a hardware issue and I should wait for an update to fix the problem. Still have the issue today... Updating to Catalina to see if that fixes the problem.
这个答案有帮助吗?
得分 0
3条评论:
@Christopher Stuart - Did you check to see if it was present on an external monitor? If you had you would have isolated out if the display was the issue or the main logic board. In your case its clear the issue is within the logic board.
I would return the system to get if fixed under warranty ASAP! This is not a defective software issue.
完成的
I use it with an external monitor daily! The issue has never shown up on the external monitor. I've scheduled a call with Apple tomorrow to complain and discuss upgrade and trade in options, since I've had multiple issues with the butterfly keyboard too. This laptop has been a complete nightmare. I just want to upgrade to the 16 inch and hope for no more problems.
完成的
Thank you so much for your answer below! I would have been waiting for a software fix forever...
完成的
添加一条评论
添加你的答案
Madeline Mackie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 594
