跳转到主内容
Troubleshooting information and disassembly guides for garbage disposals.
5 个问题 查看全部
How to replace the splash guard
How do I replace the splash guard on my disposal unit without having to dismantle the entire unit?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi Frank, welcome to iFixit.
The procedure is generally the same for most disposals, but we would need to know the make and model of yours to be able to give you the correct information.
I replaced mine a while ago and can confirm that yes, you do have to remove the disposal from the sink.
完成的
添加一条评论
2个答案
You have to detach it from the sink. Disconnect the discharge hose, unplug the power cord, and work on it outside the sink. It’s a god idea to preorder the splash guard first, so the sink is not out of commission for long.
这个答案有帮助吗?
得分 0
添加一条评论
If you are talking about the rubber piece right at the top of the garbage disposal, you simply take a flat head screwdriver or needle nose pliers and pull it out and insert the new one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank Cich 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 42
总计 1,843
