跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
Home button only unlocks since screen replacement
Hi, Since I replaced a iphone 8 plus screen yesterday. I find now the home button only works when unlocking the phone only. It does not work when trying to close any app or settings screen. Can anyone help resolve this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Do you still have the original home button?
完成的
添加一条评论
1个答案
已选择的解决方案
Occasionally this is just a software issue. Try powering it off via Settings (as opposed to holding the power button) and then rebooting: Settings-> General-> Shutdown-> Slide to power off.
Alternatively, the home button cable in the screen backplate may be poor quality, and I would try replacing that or the screen if you’re able. Worst case you could have damaged the flex cable on the home button itself and that really isn’t repairable.
这个答案有帮助吗?
得分 1
3条评论:
I have the original button. It scans my finger without any problems. So I doubt I damaged the cable? Perhaps it is the screen then. I don’t have another one to try it with at present.
完成的
@chrismax2 I'm aware. I take it the software fix didn't work? It's still possible the home button was damaged when you removed it, it's incredibly fragile. But the cheaper solution would be to try another screen first. Especially because if the home button is indeed damaged it is irreplaceable.
完成的
The person I fixed it for text me today, after 5 days of not working it started to work on it's own. So sounds like it was software related.
完成的
添加一条评论
添加你的答案
Chris Harris 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 6
总计 172
