跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
375 个问题 查看全部
Is there a way to replace the SIM card reader? Is soldering required?
My SIM reader has been damaged due to a foreign particle getting in, and removing this foreign particle has caused one of the SIM reader’s pins to be damaged.
In the hope of making this device being able to read the SIM again, how hard is it to do this repair, and is there a guide I missed looking at?
Thank you for reading.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Just looking at the iPhone XS及XS MAX拆解 you can see this will be a very big job! You’ll need to either have Apple replace your logic board or find someone that has the deep skills to fix your phone. Check out Jessa Jones iPad Rehab Youtube vids She also visits us here when she has time Jessa Jones @jessabethany
这个答案有帮助吗?
得分 1
3条评论:
Actually Dan it is not that hard of a job. I reluctantly did one of these repairs last week and it was a lot easier than I thought. With some low melt alloy and a preheater it took around 30 minutes to replace. The time consuming part was removing the under fill around the caps and resistors nearby. I was worried about heating the wifi chip up to much but if you are using a pre heater you shouldn’t have any problems. I wouldn’t advice anyone who doesn’t have microsoldering experience to attempt this repair though.
完成的
@imicrosoldering - Your skilled and have the right tools! That makes a big difference. Which is why I was aiming Aloysius to someone like you to fix his logic board, Apple won't do that ;-}
Chris - How about filling in your info card so have another skilled person listed doing repairs.
完成的
I’m pretty distraught now knowing that I sent in my phone to Apple and they broke my touch screen instead, and I am hoping to do this repair for the SIM card on my own assuming I get to fix the touch, but if a lot of parts need to be purchased then I’ll probably just let the phone collect dust. Even without the Sim tray I can at least play games on it. Now I can’t do anything. Arguing with Apple did nothing either.
I also happen to be in Singapore which I will assume, is not in the same country as you guys.
完成的
添加一条评论
添加你的答案
Aloysius Ang 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 830
