跳转到主内容
The Logitech Dual Action is a USB, PC controller for gaming. Model number: G-UF13A.
17 个问题 查看全部
Is there a way to change the placement of the D-pad and left stick?
Hi I have a Logitech F310 Wired Gamepad.
I am seeking an experience closer to an Xbox controller, meaning that the left analog stick is closer to the left thumb (where the D-pad is currently). I recall seeing a video a while back about a controller whose d pad and analog sticks could be physically reconfigured and repositioned on the fly, so I wondered if there was some way to do this with this gamepad?
For a $30 controller, I don’t expect that there is, but if there happens to be, I would welcome any information!
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If the controller is not designed for D-pad switching then there is no way you could do that, the only solution is to make huge changes but it’s really not worth it and there is small chance for that to work properly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 7
总计 1,226
