跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
iPhone 4 time is December 31 1969
I got an iPhone 4 off ebay in a parts lot. After disconnecting and reconnecting the battery for no reason, the phone time shows December 31 1969. One of the Liquid indicators in the motherbord is RED. Could the incorrect date be a sign of water damage, even though I think the date was correct before unplugging and reconnecting the battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
When the battery is unplugged the date and time is reset because there is no battery on the logic board to keep the date and time in memory.
The date and time will retain if the battery is not too flat or unplugged, when the phone is connected to internet it will re-synchronize the date and time to current time if date and time is set to do it automatically in settings.
The LD indicate can be a indication of possible liquid damage note that these stickers turn red even from just humidity.
这个答案有帮助吗?
得分 2
1条评论:
OK, I will connect the phone to internet and clean the board with Alcohol to get rid of possible liquid damage
完成的
添加一条评论
添加你的答案
Dinan Blueje 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 136
