跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Battery changed but still drains up super quick
So my battery basically was already dead. But after I changed it, I notice the new battery also drains up super quickly. Wondering if there is any other parts that I can replace to solve this problem? Thanks? Or could it be a software issue ?
Here is the new test and updates:
05:52 PM fully-charged:
06:09 PM 87%:
06:40 PM Dropped to 6.5%:
07:01 PM Dropped to 6% and received a low battery notification:
07:23 PM Dropped to 2%:
07:44 Computer Shut Down, then I put the charger back.
07:52 PM Back to 5%:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Install this gem of an app CoconutBattery, take a snapshot of the main window so we can see whats happening and paste it here for us to see 在已经存在的问题里加入图片
完成的
@danj
Hey Dan,
I just uploaded the screenshot! Thanks
完成的
@eavl776 - At this point the battery looks OK! Now from this disconnect the MagSafe charger with the system running watch a few YouTube vids take another look did it drop a little or a lot? If a lot take a snapshot again, repeat watching the YouTube Vids. After two hours take a snapshot again. Post them here for us to see.
完成的
@danj Hey Dan, the greatest person on earth. I finished the task, please check out the updated post. Thanks!
完成的
I'm still not sure if you really have a battery issue or have a power drain issue on the logic board. A defective battery tends to also show less life felt besides a low charge.
Did you have a liquid spill or sit your system down on a wet surface?
If you charge your system up again with the system turned off and the MagSafe still connected with the bottom cover pulled off place your hand on the logic board does it feel cool or is part of the logic board still warm when it shouldn't be lets say an hour after turning the system off..
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
Sadly, it came back to bite you ;-{
The solids within the drink solidified and over time the corrosive action has damaged your logic board and/or the components on it.
You'll need to find someone who can salvage your logic board or you'll need to replace yours.
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much anyway!at least I learned more about my laptop! @danj
完成的
添加一条评论
添加你的答案
eavl776 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 83
