跳转到主内容
The Chrysler 300 was designed as a modern interpretation of the Chrysler C-300, featuring a large grille, long hood and low roofline that was prominent on those vehicles.
6 个问题 查看全部
How do I fix a open closed loop on my 2006 Chrysler 300
It said I had a bad fuel injectors and it said circuit 2 so I change that and then it said something about a fuel Loop and after I changed injector it still made a ticking noise and the code reader said the same thing
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Never trust a code reader, have the items that the code reader said is bad inspected directly with an oscilloscope. Your explanation of the problem needs to be a more detailed explanation please. What was the code exactly. In order for a computer to go into Closed Loop, the oxygen sensors need to be fully hot and working. You mentioned circuit 2, that may be Bank 2 or it could be sensor #2. We don’t fully understand your problem, more details please. Also what is clicking? One of your fuel injectors is making clicking sounds?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Amanda Phillips 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 465
