跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
387 个问题 查看全部
PS4 Pro: Power ribbon cable replacement for power button on console?
So I recently bought a used ps4 pro where the power button (on the console) doesn’t work. I opened it up and turns out the power ribbon cable for the power button is missing.
I’d like to replace it, problem is I’m not sure what ribbon cable it is. Any suggestions / clues?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi, I know I am late, but I am in the middle of a project in which I need to extend the ribbon cables within the playstation, so I am getting familiar with them. From what I can tell, the ribbon cable is the exact same as the 9-pin ribbon cable on the disk drive. That being said, there are numerous replacement cables for the drives on ebay. Here’s a link: https://www.ebay.com/itm/Bluray-Drive-Fl...
If you don’t want to buy all three, just look around for “disk drive flex ribbon cable to motherboard for PS4” and find the thinnest one.
Good luck!
Justin
这个答案有帮助吗?
得分 0
1条评论:
After posting that I just realized you are working on a PS4 Pro, while I am working on a PS4 Slim. Not sure how different they are, as I don't have access to a Pro, so definitely look into that before purchasing if you are still working on this project.
完成的
添加一条评论
添加你的答案
Ryan James 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 989
