跳转到主内容
加入维修社区 - 创建账户
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
MacBook air replace screen
My mac book screen is broken so i buied mac book display assembly.The repair is almost over and i tried to put the connector, but the connector does not put in. How can i repair this mac?
https://youtu.be/kyrljFnByPY YouTube from 4 minutes 10 seconds
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This is attached to the MacBook body I had
完成的
添加一条评论
1个答案
最有帮助的答案
It looks like you got the wrong display assembly!
Here’s the correct one MacBook Air 13" (Mid 2013-2017) Display Assembly.
In your pictures you can see the long cable LVDS you have (held by the tweezers) needs to be much shorter and also uses a slightly different connector than the correct displays LVDS cable.
You’ll need to take it off and return it to seller.
Replace a display compatible with the model A1466 Mid 2013 to 2017 MacBook Air 13" laptop. Includes the 1440 x 900 LCD 13.3" screen, aluminum case and camera. Part #661-7475, 661-02397, 661-02505.图片
产品
$299.99
这个答案有帮助吗?
得分 1
2条评论:
完成的
Let's back up here You are swapping displays between two systems which are not the same model and year?
Look at it this way... A truck tire won't fit a car's rim so why would you expect a MacBook display would fix a MacBook Air? Very different part.
完成的
添加一条评论
添加你的答案
ilwootwo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 182
