跳转到主内容
The 2009 Murano made its public debut at the 2007 Los Angeles Auto Show in November and sales began in early January 2008.
6 个问题 查看全部
Does the two letters need to match or the longer number on engine?
So, I'm needing to get a new engine computer for my 2009 Nissan Murano (love the car). I've found out that it has PX and then MEC116-020 E1 8905. Upon looking though, I can't seem to find another computer anywhere with the same numbers, just the PX. I've found plenty of PX on ebay, oem, a couple pull-a-part places, etc. I heard it would need to be reprogrammed to work with my car, but I'd assume that's for the MEC116-020 E1 8905. So, do I have to get one exactly the same, if that's even possible, or I just have to get one with PX? Thanks so much! The more I think about it, the more I think the number will be the same but it would have to be the same two letters as the computer you have has. I don't know, that's why I'm asking lol. Thanks a lot again!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
As far as I know, the old and the new computer engine have to be exactly the same, otherwise you’ll get a few or more issues, it depends on the manufacturer, the difference between the computers, the car model…
这个答案有帮助吗?
得分 0
添加一条评论
May I ask how did you come to the conclusion that you need a new computer, its pretty rare that you need a new one or get a used one to reprogram, although I do admit, it does happen on occasion. I would like to bend your ear for all the information please of what you or your mechanic tested please. Did you see something inside that was burnt, like an area on the circuit board??
Its very difficult to diagnose a car here on the internet especially since you may not have an oscilloscope to test the needed components, it may be possible to test certain items with a test light or a regular volt meter but many items create a signal to send back to the computer and many items would require a scope to be sure.
Reading codes is a good start but I don’t trust codes for a final analysis, I scope everything to be sure I am changing the correct parts and if I am going to call a computer, well, lets be extra sure, again, unless its burned up.
As for the correct used computer, lets first know why you made this call, will the used one also burn up and you can see that process starting already or do we need to do more diagnosis first…….. Little things on a vehicle will change the type of computer so you need to be super sure before wasting your money, most likely you will not be able to return it?? I would only trust the exact same numbers without a professional rebuilder, reprogrammer chiming in here to give their opinion.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Evan Landrum 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 155
