跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
I replaced the battery in an iPhone 6 that was given to me, and now it
Why does iPhone 6 have a 6 character passcode after battery replacement? The original passcode is 4 characters. I replaced the battery, then let it drain and when I powered it up again it has an entirely different 6 digit passcode. What’s up with that? The previous owner upgraded at a Verizon store to an iPhone 8. The Verizon store said they wiped the 6 clean, and then it was given to me. Battery replacement worked fine, but now it magically has some unknown 6 digit passcode.
Anyone have any insight?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
“Why does iPhone 6 have a 6 character passcode after battery replacement?|
This cannot happen after a battery replacement
The only way you can set the passcode is in settings to either 4 digit or a 6 digit
It has to be physically set by a human
You are also ask to set up a password when you bring up an new iPhone or after it was reset to factory settings
这个答案有帮助吗?
得分 2
1条评论:
After I changed the battery, I didn’t power it back on for probably a month as it was an extra phone. When I did finally power it back on, it had restarted and wanted a 6 digit passcode.
I was able to force it into DFU mode, connect to I tunes and restore it to factory settings, and create a new passcode
完成的
添加一条评论
添加你的答案
Beth Wheeler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 64
