跳转到主内容
iPad Mini4 Wi-Fi版型号A1538指南 。iPad Mini3的后继版本iPad Mini4 发布于2015年9月9日。
Why can't I delete Apps after replacing Screen w/ original Home button
I replaced the screen/digitizer combo and moved over the original home button. Put everything back together, did multiple restores, and DFU restore and I still cannot delete apps. The little x in the corner comes up but pressing it does nothing. Also when installing new apps they stall or do not even show up on the homescreeen after they’ve been installed. App store shows “open” but clicking it does nothing. Any advice on whats going on here?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Ok, so here is an update. After doing all of the above, I charged it to 100% overnight. Woke up the next morning and now everything works! Surprisingly the sleep wake button also works now and I didn’t even transfer the original over! I’ll leave an update if anything changes, but so far so good.
完成的
So it’s been a few weeks and the problem persists. What’s really strange is that when the battery is at 100% the iPad works normally. Even the sleep wake button works!! Once it starts dropping in power weird things start happening, i.e. unable to delete apps, sleep wake doesn’t work, apps don’t want to install. Feels like a software problem, but I’m wondering if it’s being caused by a hardware issue.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @kwalas
Are you having these touch response problems in the same area of the screen? You can test for touch issues by moving an app slowly around the screen or by dragging the notification bar across the screen. If the screen is jumpy or unresponsive, you know it’s a defective screen. To get past certain prompts or select buttons, you can rotate the iPad and try to tap it again from a different angle.
Sleep/wake problems can also be associated with the screen. A small sensor soldered to the digitizer flex can cause these problems if its not properly installed.
I recommend trying to return this screen and replace with a different one that will give you less problems.
这个答案有帮助吗?
得分 2
5条评论:
Hey - thanks for that video. I tested the screen just like in the video and no issues. I was able to move icons, status bar around no problem. I did not however re-install the magnetic sensor flex cable as I did not need it. Could this be causing the issues I'm seeing?
完成的
If I remember correctly isn't there a small hall sensor flex for the smart cover magnet on the old screen that needs to be transferred by soldering to the new screen?
Having that without it can cause problems.
完成的
Yes, that sensor is required on the iPad mini 4 to have a properly working sleep/wake function. Many replacement screens come with a new one pre-installed, but if yours is missing or damaged that would be the cause of those issues.
完成的
Update!
So, I figured out that I really needed to transfer the flex cable sleep/wake sensor from my old screen to the replacement. At the time when I purchased the replacement I don’t think manufacturers were including them with their screens. Now it seems that they are. A quick detour to YouTube had me looking for instructions on how to solder one of these on when I noticed in the comments for the video I was watching that there is a software workaround. Basically as of this current iPad OS release, go to settings>Display & Brightness> Lock / Unlock (turn this off). Underneath that it explains that this turns your screen on/off when you have a cover installed. Tada! Turning this off fixed my issue completely! No soldering a new sleep/wake sensor required.
完成的
hey @Kamil Walas, thanks for the solution. My son's tablet broke down and i had an old ipad laying around i didnt use anymore because of this issue, so i found it, turned this option off and now it works fine, thanks!. My issue started after replacing screen/digitizer
完成的
添加一条评论
添加你的答案
Kamil Walas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 568
