跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
820-3115-B U7000 Corroded Pins, No LED on MagSafe
I have been given a dead MacBook Pro A1278. The computer is fairly heavily water damaged and on inspection has no MagSafe LED. I believe this is linked to the fact that U7000 is missing the majority of its pins!! I’ve cleaned the board and tested some of the voltage rails. The charger rail is present but everything that should be created by the U7000 chip is missing. This IC gets hot and definitely need replacing but I don’t know what to do about this inevitable missing pads under it.
I have ordered a new logic board on eBay to get the machine working for now as I think this board may be too far gone. Is there a way to transfer the serial number from my old board to the new board? Maybe if I transfer the EFI EEPROM?
Thank you,
Oliver.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Why are you thinking you need to move the EFI chip over? The new board will have its own chip and S/N
完成的
Although this isn’t absolutely necessary, it would be nice if the S/N matched the case - just me being fussy though... maybe this can be done using software though?
完成的
添加一条评论
1个答案
已选择的解决方案
All I do is take a Sharpie Pen then on the inside of the bottom cover I write the logic board S/N this is per Apple SOP!
You really don't want to mess with the EFI if you really don't need to.
FYI - Most of the time the cover marking gets rubbed off anyways ;-}
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Oliver 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 183
