跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Home Button not working
Hi after I succesfully replaced the screen on my Iphone 6s I closed up my Iphone and powered it on. Display was fine but when I unlocked my phone I got a message saying “touch id is unavailable” I opened up settings and went to sucurity and tried to enter a new fingerprint in and I got a error message saying Touch ID is unavailable I went to exit settings and saw that the home button doesn’t respond to being clicked at all i swapped back my old screen to see if the IFIXIT screen was faulty and the home button still didn’t work im stumped I hope somebody is able to help me wih this I really don’t want to have to go to apple and pay there ridiculous prices. Help would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hey. First,did you disconnect the battery prior to the repair?
Is the home button flex torn? Did you check it with a magnifying glass? This is beyond common to happen. It can tear so easily. When you lift it from the original adhesive,it can tear. This may have happened. Or if you were rough with it,the flex could have bent too much,or the fpc connector could have been damaged.
这个答案有帮助吗?
得分 0
2条评论:
Hi thank you for your reply I did dissconnect the battery but I most likely did damage it I just didn't know if this was a software problem or a hardware problem. Thank you for the reply
完成的
No problem.
It is probably a hardware problem. There are people who can microsolder home button flex cables...but it isn’t usually worth the cost unless it’s an iPhone 8 or something.
Just make sure you’re connecting the flex cable in the correct orientation.
完成的
添加一条评论
添加你的答案
Lachlan Ketland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 299
