跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 个问题 查看全部
Head Scratcher CPU & ODD fans racing with SSD replacement
This one has me stumped but it’s late in the day.
Apple iMac "Core i3" 3.2 27-Inch (Mid-2010) Specs Mid-2010 - MC510LL/A - iMac11,3 - A1312 -  2390 16GB RAM
Installed a Samsung 860 1TB EVO
OWCINSIMACHDD09 Hard Drive thermal sensor
Blew it all out, not bad dust for one this old.
Everything worked great no problems, very fast. No fan issues. Buttoned her up. Cleaned exterior correctly.
Zapped the PRAM for final delivery. Now have racing CPU & ODD fans, hard drive fan is fine. It is not coming to me why this is happening.
@danj any thoughts?
UPDATE 9/23/19
Opened it back up and ensured all connectors were secure. Booted up several times and no problems. Run youtube videos for two hours. Delivered machine. Customer says TG Pro reporting racing CPU & ODD fans, hard drive fan is fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@mayer - Did you take the logic board out? Could you have plugged in the sensor into the wrong connector?
这个答案有帮助吗?
得分 1
2条评论:
Logic board was not taken out. Will go back and check it both plugs are firmly inserted, This one is tough. The cables are not long enough to misplace.
完成的
@mayer - Very odd to say the least! This series has two independent heat sinks for the CPU & GPU so having both fail/or need fresh thermal paste would be like hitting the PowerBall twice!
I'm thinking one of the voltage sensors on the logic board is firing off telling SMC to go into Safe Mode. See if enabling TG Pro fully is able to give you any additional data or run Apple Service Diagnostics to see if something pops.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 71
