跳转到主内容
Released on July 28, 2014, the Samsung Galaxy S5 mini is a cell phone that features an 8 MP rear camera, 720p display, fingerprint scanner, and water resistance. It has a larger display, increased battery life, and an updated camera from its older brother, the Galaxy S5.
30 个问题 查看全部
New battery drains quicker than old battery.
I ordered a “new” battery and followed the instructions of not charging it until the level had dropped below 10%, then fully recharging. Now the battery uses the charge even faster than the battery that it replaced.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There are 3 possible reasons for this:
1.) The new battery is defective
2.) The new batter has a lower mAh rating, thus lower capacity. The original battery should have been a 2100 mAh capacity, compare that to the replacement.
3.) Clear the cache partition first and observe the phone for at least 24 hours.
  • Turn off the device.
  • Press and hold the following three buttons at the same time: Volume Up key, Home key, and Power key.
  • When the phone vibrates, release the Power key but continue to press and hold the Volume Up key and the Home key.
  • When the Android System Recovery screen appears, release the Volume Up and Home keys.
  • Press the Volume Down key to highlight wipe cache partition.
  • Press the Power key to select.
  • When the wipe cache partition is complete, Reboot system now is highlighted.
  • Press the Power key to restart the device.
Edit: Found a 3rd possibility to add.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Mason 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 82
