Power button is turned on but laptop not working
I try to turn on my laptop the power button ia turned on but it's not working give black screen and fan is stopped
Please help
Hi Mohammed, you had just encountered a black screen issue, you may want to try this…
1. Turn the laptop off (not sleep or hibernate but off).
2. Connect an external monitor to the laptop.
3. Turn on the external monitor.
4. Turn on the laptop.
NOTE: You may have to press an "external monitor" button. Could be the f4 button or a button with two monitors on it, for the external monitor to work.
If you can see fine on the external monitor, then your attached display, or the ribbon cable that connects it, are your problem.
If you can't see on the external monitor at all, or the problem occurs on the external monitor as well, then it is probably the graphics card/GPU that is the problem, which may require the motherboard be replaced.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 15
总计 231
