跳转到主内容
Repair information for printers made by Canon.
427 个问题 查看全部
How can I print without using a color ink cartridge? TS5410
Hey there.
My black ink cartridge is full, whereas my color ink cartridge is empty. I’ve tried to print papers in grayscale (black and white only) using settings on Windows, but my printer (Canon TS5410) is rejecting the request with error 1688. How can I bypass this?
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Follow Solutions to Fix Canon Printer Error 1688:
The issue is not as big as it seems and can be resolved easily following some simple steps
Solution 1: Resetting of Ink Level Manually
Step 1: Click on START button and open CONTROL PANEL.
Step 2: Select Printers and Faxes on the computer system
Step 3: Open up the Maintenance Program; select Canon Printer Preferences in Dialog box.
Step 4:  Check the INK Leven warning indicator in the maintenance section.
Step 5: Disable the Ink level warning indicator by selecting the Radio Box next to the option.  By doing so, you will disable the warning message, resisting it from appearing on the screen again.
Step 6: Click on “APPLY” to save the changes and close the dialog box.
Solution 2: Holding Stop/Reset/Resume button for five seconds
A series of Canon printers allows users to continue printing on a single button press. User can hold down Stop/Reset/Resume for five seconds and then release it. By doing so, you can continue printing regardless of the low or empty cartridge estimate.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rare Pepe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 3,686
